A Big Thanks to Michael Rudolf (Screamn03) for thinking of a TToC way back in 2007 and making the effort to create it! Another special tip of the hat to both Michael and Bill (2kbill) for their continued maintenance and support in the early years. Both of you have contributed significantly to the utility of the ModFords Website with this indispensable asset — Ed
"Look here for threads related to some of the more pertinent information in this forum"
WIP Note: This project is currently under construction, so more content will follow. This is being done to keep the sticky'd threads to a minimum and also to provide a central resource of good tech threads related to Terminators. This thread will remain locked to keep all posting in the threads themselves and to keep this thread as organized as possible. If you wish to discuss this TOC or any other ideas for this forum, then please feel free to do so in this thread 'click me', your input is valuable to us
If you have a (or know of a) thread that you'd like to be added to the list or a thread that you don't feel should be here, then please PM a member of your friendly ModularFords Staff.
General
General answers for 03-04 Cobra (mods, cost and performance)
2003 Ford Mustang Repair Manual
600 hp On An Eaton!!!
Hilton Boost Overlay How To Video - XSELLR8
All Things Terminator - Joe Goffin
Bolt-Ons
Electrical
Alternator pulley reference chart - Senkak
Terminator "Alternator 101" - Joe Goffin
Safeguard Vampire Install - Smokin04
Alternator & Wiring Upgrade Video Tutorials - XSELLR8
Engine Tech
03/04 Cobra Vacuum Lines Documented - Mark Olson
Sparkplugology 101 - Eric Brooks
Proper Spark Plug Installation - Ed Schaider
Inlet Components CFM Rating Breakdown & Improving Upon! - RWTD
Summary of blown engines - black2003cobra
Teskid Block in a Terminator
Fully Flanged #5 Upper, - rtusnake
Volumetric and mass-air flow rate calculator for a 4-stroke IC engine - black2003cobra
How to Degree a Set of Comp Stage III Cams - Steve Boing
Effectiveness of Engine VE Changes with a PD Supercharger - black2003cobra
Basic PD Supercharger Tech and Compressor Map Analysis - black2003cobra
Increasing CR vs boost pressure - black2003cobra
Cam and Valve Timing Spreadsheet - Ed Schaider
Valve Timing Calculator by Mark Olson
OK So Where Do I Set My Cams? - Ed Schaider
Cam Selection & Phasing - The How's and Why's - Ed Schaider
J. Mihovetz Cam Thread
Head flow from Official 4V Head Tech Thread
Short Stroke Terminators - Ed Schaider
Oil Separators & Open Breathers: Why are they still being used?
Timing Guide Pivot / Dowel Upgrade - Ed Schaider
Primary Chain Tensioner Modification - Ed Schaider & Joe Goffin
Crank Tech I - Ed Schaider
Crank Tech II - Ed Schaider
Ford Timing Kit Installation Instructions - Allen Garrett
Secondary Cam Drive Chains - One More Time - Ed Schaider
Custom Billet Supercharged Modmotor Pistons - Ed Schaider
Squish, Quench, Compression Height and Other Mysteries of the Universe - Ed Schaider
Cam Phasing - An Easier Way - Ed Schaider
M10 Side Bolt Upgrade - Ed Schaider
How to Degree your Cams in 1 Hour! — Kevin S
Engine Builds
A Complete ModMotor ARP Fastener Listing - Ed Schaider
Why You Want to Use Standard Size Bores - Ed Schaider
Teksid / Aluminator / Others - Which Block to Use? - Ed Schaider
03Steve's Build Thread
Setting Adjuster Pre-Load - na svt
Smokin04 build thread
BLK_03 build thread
Mofasta's BOSS 5.0 Build Thread
Smart Things to do When it Comes to Head Gaskets
Zach's Build Thread
Lucheski's Build Thread
Cam Phasing Videos - Screwonbudnik20's Build
My Aluminator Gibtec Build - Joe Goffin
Blower Tech
Basic Positive-Disp Supercharger Tech and Twin-Screw Compressor Map Analysis - black2003cobra
Boost estimate calculator for positive-displacement blower - black2003cobra
Why restrictions in the intake tract are bad - black2003cobra
Summary of ported Eaton data - black2003cobra
Summary of 2.6L & 2.8L KB data - black2003cobra
Post your KenneBell numbers here....
Whipple numbers
3.4L Whipple Users
Found the big boost drop off problem with the whipple - Dave King
Eaton Pulley Combo Reference
2.2L KB Pulley Combo Reference
Initial Killer Chiller Review - Tractionless
Compression efficiency and intercooling - black2003cobra
Voltage Booster for IC PUMP - Jon Pavia
Nitrous
N2O Dry Shot Nozzle location
Nitrous/Eaton combo?
Suggestions on nitrous location (stealth)
Stoichiometry - Nitrous oxide injection
Turbo
[Turbo TOC coming soon!]
Summary of turbo data
Dyno CF for a turbo
Turbo Cobra BSFC & rwHP vs mass-air flow rate
Cooling System
Keeping your cool.
Simplfy your cooling system
Mark VIII cooling fan question
Exhaust
LT's...1 5/8" or 1 3/4"?
Long Tube header primary tube sizes?
Coated Mild Steel or Bare Stainless Steel - Which Holds the Heat Better?
Fuel System Tech
MS3Pro PnP EFI For Terminators - Ed Schaider
Blower Discharge Temp as a Ć’ of Boost - Ed Schaider
Understanding our fuel system - Multiple Contributors
Fuel Injector Sizing Spread Sheet - Black2003Cobra
Fuel System Calculator R2.11 - Ed Schaider
Why You Want a Balance Line on Your Fuel Rails — Ed Schaider
Stock MAF, Injectors, and Fuel Pump Power Limits - By RWTD
Stock Fuel Pump Wiring Upgrade - Blk_03
Ford GT Pump Info - Look Inside
Two FPDMs, one for each fuel pump - 03 Steve
BAP or dual gt pumps? -RWTD
Doesnt anyone go return style anymore?
EVAP Removal: How to properly disable in the tune! IMPORTANT! - RWTD
EVAP Removal Value File for PRP S/W - Eric Brooks
PPRV Delete for Dummies - Clay
BAP users, look here - Sonic Venom
Tuning
All those interested in tuning - Time to bring the tech
Timing Recommendations
Timing advance/retard affects on EGTs & knock
Oxygenated fuel
Stoichiometry of blended fuels (gas + alcohol)
Stoichiometry of gasoline + toluene
Stoich Points of Race Gas
Meth results summary thread
Snow Methanol Injection
Why is no one running meth/water or alky?
Headers impact on AFR
Understanding fuel trims
Wideband accuracy facts and issues
Returnless System Hesitation I
Returnless System Hesitation II
Returnless System Hesitation Fix - Jerry Sutton
Tuning Workbook-Pro - 03Steve
Detonation - Ed Schaider
How to Read Plugs - Ed Schaider
Trans and Diff
Official Clutch Summary Thread - Please Post Your Review
Cobra Clutch Replacement Video - Danny Johnson
Master Housing Depth Ring & Pinion Setup - Ed Schaider
Resealing The Diff
Installing a Long-style Clutch in a Cobra - Hardcore Ratt Fink Tech!
Proper Installation procedure for Twin Disc Clutches
Steel or Alum Flywheel
Flywheels: aluminum vs steel
2003 Cobra IRS to 8.8 Live Axle Swap (DETAILS & PICS)
Auto Install Guide by Dave King - raw diagrams found here "click me"
4R70W Swap Using Mach1 PCM - Custom Wiring Schematic thanks to DynoDan
8.8 differential carrier clutch pack question....
Factory Clutch Pack Replacement
Homebrew Dual Disc Clutch
TH400 Build w/Aftermarket Reid Case
Suspension/Brakes/Chassis
03 Cobra's with stock IRS cutting 1.5 60' come in here!
OFFICIAL Weight Reduction Thread
Wheels/Tires
Post up pics of Bigs and Skinnys!!!
Dynograph
Ice Box/ Additional HP Debate....
Air density (dyno) correction factor derivation
Dyno CF for a turbo
Effects of gearing on power
Track
1/4 Mile Estimates from 1/8 Mile Results
Offical:6speed / IRS / Twinscrew / No Nitrous List:
E.T List and Modification Idea!
Quickest/Fastest 03-04 Cobras
General
Bolt-Ons
Electrical
Engine Tech
Engine Builds
BLK_03 build thread
Zach's Build Thread
Blower Tech
Whipple numbers
3.4L Whipple Users
Nitrous
Turbo
Dyno CF for a turbo
Cooling System
Keeping your cool.
Exhaust
Fuel System Tech
Tuning
Oxygenated fuel
Trans and Diff
Resealing The Diff
Wheels/Tires
Dynograph
Dyno CF for a turbo
Track
